Oaklevel
Jan 01, 2014Explorer
Old-Biscuit wrote:
Suburban WH?
One ON/OFF switch with light on panel inside?
IF yes........
The On/Off with light is for propane operation
The On/Off Rocker switch located in outside compartment is for 110V AC electric heat element.
If light stays on...'fault' has occurred
If on propane either the man flame failed to light/main flame didn't prove lit OR ECO (high temp t-stat) has operated (opened)
If on electric.....ECO has operated (opened)
ECO has reset..push on rubber button cover to reset 110V t-stats on left, 12vDC for propane on right.
Well most of the time our last trailer the light went out when the propane was working properly & came on if there was a problem. This trailer a 2013 the light does not go out unless there is a problem. Do wish there were all standard. (Same water heater brands & same trailer makes.)
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
