Deb_and_Ed_M
Jan 02, 2014Explorer II
Old-Biscuit wrote:
OK you have an Atwood.....
There is only one set of t-stats for the electric and propane
And no manual reset either.
The 'fault' light will come on the same.
If on electric or propane and ECO opens (cause normal has failed and it has overheated to 180*F) and on propane if it fails to light/prove main flame.
Not only are some things different between the brands but can be different between models of same brand...:B
Does it self-reset like my home furnace, then?? Just let it sit until it cools down, then try again?
Also, (since you clearly understand these things!) - I don't have an anode..... but somewhere way in the back of my mind, I think I remember that some heaters have anodes and some don't?
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
