theoldwizard1 wrote:
MFL wrote:
Adding ethanol, will cause a more lean condition, and can cause more heat, under load.
Any decent quality brand generator has bee tested on E10.
Don;t store any generator with ANY FUEL IN THE CARBURETOR for more than about a week ! If your generator does NOT have a fuel shutoff valve, you can add one for $10-$15.
I have to disagree. I also should have mentioned that Seafoam is added to every drop that goes into it. It is a good stabilizer, and cleaner. For the amount I use my generators anymore, the cost of premium is insignificant. I never drain the carb, but I do run them monthly. I also have an issue with running them dry versus draining the carb. If you add a shutoff there is still gas in the carb that can and will varnish over time, it just isn't enough gas to run the engine anymore.
Actually, yesterday my DW asked when the last time we used either of the Hondas for camping was, and it was over 10 months ago. They both start just fine. I am loving the solar!
Edit: I do not disagree with your comment about the generators being tested with E10. I should have made that more clear. :)
