TimnJo's avatar
TimnJo
Gen-turi question
Hi All,
I have a 5500 genset in the front storage compartment, the exhaust goes out the bottom of the compartment then points forward ending about 4" in front of the compartment.
This is directly below our bedroom so am nervous about CO entering the coach.
The solution is, of course, a Genturi, however all the ones I've seen have a short metal extension to the exhaust then a 90 degree bend up to where it joins the larger pipe to eventually end above the coach roof.
This isn't an option as I have to extend the horizontal portion to clear the forward overhang.
So, my question is how to best accomplish this without creating too much back pressure (is that even an issue?) and also make it easy to install and store.
I was thinking of just using 3" PVC straight out to just forward of the of the overhang, a 90 degree joint, then straight up to just above the roofline. I could attach it somehow to the pinbox for support, bungee or something for testing, then something more permanent once passed the proof of concept.
Your thoughts?
TIA
Tim
(edited for clarity)
  • When I installed our generator, I ran the exhaust to the rear of the coach, about 35', with oversized pipe. Then I install the GenTuri on it. Have used it dry camping at the race track for several years with out any issues.
