JAC1982
Nov 11, 2020Explorer
way2roll wrote:TXiceman wrote:
Montana or cedar Creek....neither one are considered higher end units. They both take their basic unit and add some bling to make it pretty. Nothing in particular is done to make the unit better except for heavier tires.
Same Lippert frame and components.
Ken
This isn't really accurate. While I will agree they aren't high end (which is a fairly loose definition as you could spend a TON of money) they certainly aren't entry level. Hung wall construction, real gel coat, residential insulation, real ducted air, screwed frame construction 16" OC, higher end suspension, the list goes on. These things aren't "bling" and you won't find them on entry level units.
Having looked at nearly every make and model from $35,000 up to $80,000 available over the span of 6 months before deciding on a Montana High Country (which is not as nice as regular Montana), I can attest that Montanas and Cedar Creeks are both definitely nicer than most unless you're getting into the rigs that are $100k+ even after the normal discount off MSRP.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 23, 2026
