nayther wrote:
Dwight45 wrote:
Oil is good. I ran it about 45min no load everything was fine. I did have the Gen door open. I'll try running it under load later. Haven't had any luck downloading
the manual. Internet not to good here.
Dwight
when you say generator door are you referring to the front cover of the generator or the compartment where it is mounted? If the former, then I'm sure it overheated, that's part of the cooling system, if the later then it should have no affect.
I agree. If the RV compartment door open all get is more noise.
