Stootz01
Oct 05, 2019Explorer
Generator dies after load
Been searching for fixes for this for months and the forums that post ideas always die without a fix so here we go.
I have a Onan 4K generator that started out dying after 10 min no matter what.
I installed a new fuel pump/filter and carb, oil change, no fix.
I took the air filter out while it was running to inspect it and noticed it would keep running but when the AC was on it would die...so I changed the air filter...no change under load but it would keep running without a load.
I then took the metal air filter cover and left filter on....would run under load but would then die after 10 min.
I then discovered there was an additional after market fuel filter on it under the RV so I bypassed it, changed the spark plug while I was at it and discovered that it would run for 30 min under load before it died.
I then discovered a youtube video of someone claiming that draining oil below the low level line would keep it going. Comments suggest that was a mirical worker and it seemed to fix the problem for a lot of people.....but not mine....
I'm getting closer to nailing this down but I'm out of ideas
Give me suggestions....I'll do it man!!!!
Gen has 216 hrs on it
