- GMHExplorer
starcraft69 wrote:
There is a good thread on here about a rack built for the 5er hitch to secure genset while traveling and to secure it from theft.
Do you have a link to that thread? Thanks. - rtaylor0830Explorer
MitchF150 wrote:
Who cares what the fuel consumption is?? If you feel you need to run it, then run it... If you care that much how much fuel it consumes, maybe you shouldn't run it??
Nothing wrong with running it while driving. Just if you feel you need to.
Good luck!
Mitch
I am not worried about the money I am more worried about how much ga to put in the tank so it does not run out. Also I thought it would be a good way to make sure I run it once a month like they say you should. - Who cares what the fuel consumption is?? If you feel you need to run it, then run it... If you care that much how much fuel it consumes, maybe you shouldn't run it??
Good luck!
Mitch - Bionic_ManExplorerI run my generator when driving at times. If properly installed, no reason not to.
Hard to estimate fuel consumption without even knowing what fuel type you have. Diesel would be the most efficient, LP the least. Mine doesn't seem to care what load it is running, consumption is near a gallon per hour. - SDcampowneroperExplorersafety risks? not likely. MHs run their gennys all the time while on the road to keep their family comfy. The fuel cost is yours to weigh against comfort.
- starcraft69ExplorerNo problem at all. As long as generator is secure. There is a good thread on here about a rack built for the 5er hitch to secure genset while traveling and to secure it from theft. GPH depends on genset and load
- lj2654ExplorerI use my roof air when I travel with the generator. No issue to do it. 1/2 a gallon of diesel an hour.
- colliehaulerExplorer IIIMotorhomes and tour bus's do it all the time.
- avvidclif1ExplorerI will run the generator while towing if the weather dictates it. As for usage you didn't say what kind or size of generator so don't have a clue. My Onan 5500 burns between .5-1gal/hr depending on load. 1 AC would not be heavily loaded so figure in 2 hours maybe 1.5 gal.
- LwiddisExplorer II"Can I run generator while towing and is it a good idea or not , also what would be the average gas usage on a 2hr drive running a/c and fridge."
Why not run fridge on propane? And who wants to RV when it's so hot you need to run the RV's A/C when driving?
About Fifth Wheel Group
19,022 PostsLatest Activity: Jul 24, 2016
