- bigalwheelerExplorerFigured it out, bad breaker...Thanks everyone for the help!
- fj12ryderExplorer IIIIs it a built-in generator like an Onan? Our Onan has double breakers on the generator that connect the generator output to the trailer.
- Y-GuyModerator
Wild Card wrote:
Keystone Raptor should have come factory with a transfer switch.
Our 2005 had a transfer switch. But I did have issues with it sticking too. - Wild_CardExplorerKeystone Raptor should have come factory with a transfer switch.
- Old-BiscuitExplorer IIIMethods of generator power
RV power cord plugs into an 'outlet' that is wired to generator output
Generator power cord plugs into RV power receptacle
Gen/Shore power are wired to 'Auto Transfer Switch' ---output goes to RV Main Power panel
(Start gen and transfer switch swaps to Gen power ---default source) - kerrlakeRooExplorerLook at your generator, does it have a plug on it that is the female match to the one on the power cord that the trailer uses?
On many, as a safety feature you plug the unit into the genny for power as a means of avoiding someone accidentally connecting to both the genny and an outside source at the same time.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
