Eyetattoo wrote:
allcool wrote:
As others have said, make sure engine is not seized before buying a starter.
"Remove the intake screen at the front of the engine to gain
access to the flywheel nut. Use a large socket and socket
wrench to rotate the nut and hence the engine in a clockwise
direction." Confirm it spins... Otherwise a starter is not going to help if engine is seized.
Is the intake screen behind the air filter?
This would be the cooling air intake screen. You need to get to the crankshaft nut to see if the engine turns over freely.
