the bear II wrote:
Do an internet search for a remote start on a Honda 3000. I've seen them advertised in RV magazines and found the company with an internet search a few years back. They had a parallel kit to hook two 3000s together.
The remote start saves you having to run outside in the cold or heat.
Yes, I found that 1 Honda EU3000i can run a 13,500 AC and it can run parallel with another Honda EU3000i which I sure can run the 15,000 BTU AC but wow, $2300 each. However the 3000i is only 80 lbs to move around which is doable.
