Oasisbob wrote:
Do you need one? Depends. Do you plan on camping where there is no hook ups for more than a day or two? If yes or maybe might as well get a Generator. We can camp three days on only our twin group 27 batteries. We then use a HONDA EU 1000 portable gen set to charge. If you have room go with a built in unit. May I also ad don't scrimp on quality. Get a quiet reliable unit such as Yamaha or Honda or Onan. Stay away from the cut rate units IMHO Best of luck
Agree with *most* of the above - not sure what "cut rate units" means.
Champion generators (including inverter type) have a great reputation and first-rate service, and are less than half the cost of the red or blue ones.
OP: Suggest you order your trailer "Generator Ready" - then after you decide whether you like to camp with full hook-ups -or- "boondock" without hook-ups, you can either add a "built-in" gen -OR- go with a portable.
Bonus:
No matter which you choose, if you decide you need one - you will get a better deal than buying from the dealer!..;)
Also, a search will yield lots of Generator/s info - mostly on the *Tech Issues* forum.....
however this thread ran on 5th wheel forum a couple of weeks ago:
"Generator or no Generator"The benefit of using "Search" - is (usually) the answer/s to your questions are already here.
No need to wait for replies..:C
