Lwiddis wrote:
A generator carried on a rear rack needs substantial reenforcement.
Much simpler...and better to bolt a mount to the pin box. The pin box is very sturdy, so no worries about it falling off...unlike the typical rear trailer bumper.
If you can live with 1 Air/Con at a time, something in the 3000-4500w range is ideal.
If you are careful, the 4500w unit likely can accomodate 2 air/con units but you will need the right adapter and you have to limit the other stuff you run.
Yes, in theory you can use solar battery but by the time you build a system that can let you run air/con any reasonable amount of time, it's a whole lot cheaper and simpler just to get an appropriate generator and pay for the fuel.
