way2roll wrote:
Sounds like it, with a MH, you need to weigh loaded for travel and subtract from the GCWR to ensure there is enough for the toad. With a FW it sounds like I need to make sure the truck can handle the load of the PIN, plus what's in the truck, plus the tow weight of the FW loaded for travel. Going out on a limb that most modem FW have brakes right? (that could be a bold assumption)
We have a supplemental braking system on the CRV when we tow it behind the MH.
Yes you need enough payload with the truck to carry 20-25% of the loaded trailer weight. Plus the people and cargo loaded in the truck. A SRW F-350 is the same size as a F-250, but has a greater load carrying capacity. Cost should be very similar as they a 95% the same truck.
