Thanks for the reply, I measured the brackets that connects the leave springs to the frame to the front of the trailer and back of the trailer, my driver side is over 1/4 inch further back then the passenger side. I don't know what the specs are, but I thought that both sides should measure the same in order for the axles to be parallel with the frame. I met a guy from Sedona, almost same trailer, he had exactly the same wear pattern as mine. Mine has now 2400 miles on it. Pattern as followed:
Driver side front: perfect
Passenger side front: badly worn down( not safe anymore)
Driver side back: really noticeable wear on outside only.
Passenger side back: really noticeable wear on outside only
How can it be that we have the exact same wear pattern?
