MandKJohns
Jan 24, 2017Explorer
Usually on a carburetor the low idle needle will get partially clogged. Even though you run gas thru it once a month that may not be enough for that particular carburetor. I would run either some mechanic in a bottle or some Stabil thru it and see if that helps. If not you may need to have the carb cleaned.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
