lincster
Jan 24, 2017Explorer
Strabo wrote:lincster wrote:
Wanted to see what others thought.
Genny just started acting like this.
Fire it up, runs rough for 5-10 min, then cleans up and runs perfect.
I have never let the carb sit for more than 1 month without running gas through it.
Change the plugs/filters etc per the schedule in the owners manual.
In fact, air filter gets changed every 150 hours with the oil and oil filter.
Changed plugs per the manual.
Any ideas?
I know thru the years of being a member in here, that you take good care of your stuff. I can't remember the last time you asked for advice on something. My thoughts, same as the others. Run some seafoam thru it, worked on ours years ago when our genny did the same thing.
Well thanks Strabo.
I don't ask for advice often, you are right.
I either know how to fix it or learn from other posts.
I will buy a can of seafoam tomorrow and run it through this weekend when I am at the dunes.
If I do have a choke problem, what do I do to fix it?
Is there a mechanical adjustment?
Is there a diaphragm in the carb?
Haven't dug into one of these before.
Usually just say "replace the carb". LOL
Thanks all for the advice. I will report back after my weekend.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
