baker01
Jan 28, 2017Explorer
Here is a link to a pic of the carb. It is the silver canister upper right side.
Onan carb
A quick way to check it. Pull the air cleaner element out. you should see the choke plate is almost completely closed (only do this with the gen cold). Start the generator the choke plate should open slightly more but not all the way. If it does not move, open it slightly with your finger. If the stumble stops It is most likely a bad canister or vacuum line going to it. You will have to pull the carb to test the canister.
Onan carb
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
