baker01
Jan 30, 2017Explorer
The Onan vacuum pull off is not cheap at $55-70. I tried to match up an automotive/small engine unit and could not find one that would fit. here is a link to a cheap vacuum pump tester http://www.harborfreight.com/brake-bleeder-and-vacuum-pump-kit-69328.html You put vacuum to the canister the arm on the unit should suck in and stay in. if it moves back out you have a hole in the diaphragm
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
