baker01
Feb 04, 2017Explorer
From the manual
Electric choke assembly and vacuum breaker assembly (Figure
8-10). Conduct the following checks and adjustments
before replacing a carburetor/choke
assembly:
1. Apply 12 VDC across the heater terminals. The
choke should open fully in 2 to 3 minutes.
2. Check the heater alignment marks and realign
if out of alignment. The choke should be closed
at temperatures below 70° F (21° C). It may be
partly open above 70° F (21° C), but should
close almost completely when vibrated (engine
cranked).
If your choke is open when cold it sounds like it is out of alignment. You should be able to loosen the three screws on the choke to adjust it.
assembly:
cranked).
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
