Sam_Spade
Feb 05, 2017Explorer
baker01 wrote:
If your choke is open when cold it sounds like it is out of alignment.
OR the internal mechanism that closes it has broken.
When COLD you should feel some spring tension that is trying to close the choke plate. If that's not present, it is WAY out of adjustment.....or more likely the thermal spring is broken.
This is the kind of automatic choke that was used on pretty much ALL gasoline engines for maybe 30 years or more. A high percentage of the springs failed after enough miles/hours; or they corroded badly, because the heating mechanism was a tiny pipe carrying exhaust gasses.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
