Sam_Spade
Mar 03, 2017Explorer
lincster wrote:
Well, now it won't start hot.
The butterfly is completely closed. I don't get it. Ugh.
Which butterfly, choke or throttle ?
I assume choke.
On this engine, what actually causes the choke to open ?
On some it is air flow (engine vacuum).
On others, there is an electric element attached to the choke plate via a bi-metal "spring". When it heats up, the spring opens the choke.
You first need to determine how it is SUPPOSED to work before figuring out why it is not.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
