Lantley wrote:
Thermoguy wrote:
Wow, so many people overthink this. Getting gas is simple and many gas stations have large areas that are not an issue for a truck and trailer. I have a diesel but never go to the "truck" island, always the same side as vehicles. It's probably harder to get diesel as there are limited pumps and you often have to wait for an open pump. But, if you are traveling on the interstate or highway, most if not all stations are going to have ample room. I can't even recall backing out unless there is a car at the pump in front of me and I can't go forward or don't want to wait. Just look before you drive in the driveway, if it is too tight, go to another one, usually across the street. I think I spend more time looking for the price then looking if I can get in and out. This really is a non issue, or at least not worth stressing or even planning in advance. I have never looked at Google to see if the station is large enough. If you wanted to gas up in the city, then you might have to think a little harder for a station with room, but no the interstate, don't even worry...
You claim that it is not an issue then you mention if it's too tight go across the street......THe idea is to pull into an accesible place the 1st time!
Getting gasoline while hooked often requires effort.It's not as easy as getting diesel.
It's not the issue of our lifetime, but it is worth some discussion and often requires some planning/scouting.
My Point was, you can tell before you try to pull in if it is a good gas station or not. Along the interstate I would venture to guess 90% of gas stations can accommodate a larger rig. Not at the Diesel island, at all islands. I drive a diesel but always use the standard islands, don't like the dedicated truck islands and I'm not one to get in the way of a commercial trucker. I have never planned ahead other than to only stop for gas when I can see that there are multiple choices or that the station can accommodate me, this is easy to see before you take the exit. Also, if there is a Love's or other truck stop, I have found the gas islands are wide and easy to get in and out of.
