valhalla360
Jun 29, 2022Navigator
Mondooker wrote:
Hey Cummins12V98, That’s great information and the pictures really helped pull it all together. Thanks for that.
I’d like to be able to put a pull out tray on mine but not sure I have the vertical clearance for it? Someone said go from 30 Gal to 20 to gain space. But I really don’t want to lose 20 gals of propane.
I’m frankly surprised someone hasn’t devised an elevator system, maybe like a tire Jack.
Pounds not gallons. Honestly, unless you are going thru propane fast, switching to 20lb tanks would be a good option. It reduces the weight and gives you more room to work with. I grumbled a bit as our latest trailer came with 20lb tanks but we are only going thru 1 tank ever couple months full timing, so it hasn't been an issue (once a month in cold weather but usually heading to warmer destinations in that situation).
As far as elevator systems...fact is there probably isn't much of a market for it.
- Most RVers are physically capable. When you are no longer capable of lifting the propane tank, good chance you are facing other physical challenges to RVing.
- The rest can usually find family/friend to help them with the once every couple month task.
- That doesn't leave very many who would benefit from a specialty product.
One option you might be able to do: Swing by the hardware store and pick up some pulleys and rope (sufficient for a 4-1 arrangement, higher ratio if you think you need it). Mount an eye to the top of the compartment to support the pulley system.
A 30lb propane tanks weighs around 55lb, with a 4:1 arrangement, you set it on the ground next to the compartment and tie it off. It will then take around 15lb of pull on the pully to lift the tank.
- With one hand hold the tank out so it doesn't hit the side of the trailer.
- With the other, pull on the rope.
- Take your time so you don't trip but then step on the end of the rope you can move your hand to a new position. (with two people it would be a breeze but then you probably wouldn't need mechanical assistance)
- Once even with the compartment, let it swing into position and let out the rope to set in place.
- Reverse the process to take it out.
If you wanted to get fancy, you could rig up a small 12v winch on the top of the compartment. One hand to control the tank and the other to work the control.
About Fifth Wheel Group
