larry_barnhart
Jun 29, 2022Explorer
Cummins12V98 wrote:
On my Dads new to him 5er you had to lift the tanks "UP" and out of the steel ring or try to release the latching system and bend the steel horizontal ring out of the way so you could tip it out instead of lifting. .
So I put my "creative genius" ;) to work and cut off the latching system and added a strap that can be tightened. Works GREAT with releasing the strap and tipping the tank out and grabbing the bottom to easily carry it to the truck. I added a wood block to keep from damaging the aluminum door frame at the bottom. The block also keeps the tank base locked in place.
I didn't like the factory setup either so because of sitting for 6 months I removed the clamps but installed them for the trip home.
chevman
About Fifth Wheel Group
