donn0128
Aug 14, 2016Explorer II
Usually refer circuit is not GFCI protected. Turn the refer breaker off, go out and take the outlet apart. Then using a volt meter check for voltage directly at the wires. If its dead, start tracing wires. If your refer in in a slide out, start at the junction box under the slide out.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 27, 2025
