minnow
Aug 18, 2016Explorer
I agree with rockhillmanor; check the GFI outlet, then check to see if a circuit breaker in your panel is bad(can be the same symptoms as the GFI outlet - looks OK and trips fine but is not). That is easy to do, just take a good breaker from the breaker box and swap it with the suspect one.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
