BB_TX wrote:
Get a tester like shown below and plug into a working non GFCI outlet. Then connect RV to shore power and check for correct power. Then plug RV into your generator and again check for correct power. I am thinking you will find an open ground when connected to generator.
  As a CG host in a state park all I was allowed to do when a camper complained about power issues was plug that type tester into the post, using what adapters needed (50-30, 30-15, you know, things that can burn snot down if miss used) If the lights came on as expected, "Sorry, the issue is in your camper." Now, unless the camper was acting like Richard Noggin, I would ask if they had any outlets not controlled by GFI, and offer to let them plug my tester in. It would tell them the issue.
  The breakers in your panel trip when currant flow exceeds limit. But because some things put a much larger load on for short time they will handle large load for short time. If breaker let the starting load run for long that little wire would burn up, maybe burn the house down Breaker don't know if that extra load is starting the garbage disposal, or if the maid is touching a bare wire and the faucet. In the time it takes to start the motor, the maid might be dead.
   GFI, compares hot and neutral. Normal operation there is no reason for there to be a difference, so instantly stops flow.
 Breakers and fuses are to protect things, GFI is to protect people.
