atperci's avatar
atperci
GMC 3500HD with Gooseneck hitch but want to use BW Companion
We are in the process of moving from a motorhome to a FW, so I am still learning all the ins and outs of the hitches and all that is required for them.
We are looking at a 2015 GMC 3500HD DRW that has the gooseneck hitch prep package, but I would like to use a B&W Companion hitch. I have read that the GM gooseneck hitch is actually a Curt EZr and uses a rounded shank vs. the B&W Turnover's square shank and that the two are not compatible.
My question is, does anyone know if (or can) the Curt is replaced with a B&W Turnoverball hitch under the bed of the truck, will the holes line up? Last thing I would want to do is have the two holes slightly out of alignment.
Thanks for the help!
Tom
  • Thanks for the replies!
    We don't have the truck or the hitch, yet. Just trying to figure out how it could work. I didn't know the Andersen Ultimate would work with a gooseneck hitch (like I said, I'm still trying to grasp all the concepts involved with a FW.) I have read good things about Andersen, but also B&W.
    All the trucks I had been looking at (Ford and GM) had the fifth wheel puck system, which is why I was thinking only about B&W. Then I found this one, which meets all our criteria at a good price, but had the gooseneck instead, so I was stuck not knowing how a FW hitch would work without major modifications.
    I'm going to do some more research on the Andersen, to get a better grasp of its features and usage.
    Thanks again for the help!
    Tom
    Tom
    Is it only the gooseneck prep package or gooseneck/5th wheel prep package? I only ask because you should have the center hole for the gooseneck ball and 4 smaller holes spaced evenly in the bed around the center gooseneck ball. If you have those you should be able to get the B&W Companion for the Chevy prep package item# RVK3700. Here is a link to the hitch. RVK3700
    Hope this works for you.
    If you already have the Companion hitch and want to reuse the hitch head, you just need the puck-mount base assembly - RVB3700. That will save you hundreds of dollars.
    Rusty
    Tom
  • If you really want the B&W they make a 5th wheel hitch that drops down in the gooseneck ball mount. Or go with Andersen Ultimate.
