TXiceman
Aug 20, 2014Explorer II
As advised, carefully check your available pin load capacity based on the real weight of your truck ready to camp.You will find that a 1/2 ton truck will be limited by the rear axle GAWR and GVWR. A 5er will impose a higher pin weight that will the hitch weight of a travel trailer. So your limiting capacity will be the trucks true payload capacity ( that is what is left over once you load cargo and passengers in the truck).
Practically speaking, most 1/2 ton trucks will max out on pin weight with about a 24' 5er.
DO NOT listen to the Rv sales person. They seldom understand tow ratings and limits. A 1/2 ton towable trailer will only be OK if you tow the trailer empty and never have more than yourself in the truck.
Ken
Ken
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
