avvidclif1 wrote:
SolidAxleDurango wrote:
avvidclif1 wrote:
You do realize that all the reports of bad blowmaxs have been the "E" rated ones run near max.
this is not true
Please post the conflicting reports.
No need to post anything to prove how my statement is true.
Common sense however, tells me that your statement is not true.
ALL reports of bad blowouts (what's a bad blowout vs a good one?) have been E rated that were run near max? You analyzed every single one of them? And they ALL were near max? No you didn't and no there were all not near max.
I had a blowout on an E rated one and I was not at max. So essentially because I reported one (that you must have missed since you reviewed all of them) and my failure makes your statement false.
And I have what I suspect is a pretry fairly common sized 5th wheel considering there are so many Montannas on the road.... A similarly sized 14.5K or 15K GVWR trailer.... I have 10,300 lbs on my trailer axles.... Well below the 14,080 overall tire capacity.
