Most times, the specified torque value assumes clean and dry parts. Clean means no dirt, rust, dried-up gasket sealer or anything except shiny metal. Some fasteners, like head bolts or main cap bolts, are often specified to be torqued with 30-weight engine oil wetting the threads and washer. If you're installing a fastener that has a dry torque spec, and the threads and bolt face are oiled, you'll need to reduce the torque by 15 to 25 percent, because the slipperier surfaces will decrease friction. Teflon-bearing lubes or moly-sulfide engine assembly lubes can reduce friction enough to require a 50 percent reduction in tightening torque. Even casually substituting a zinc- or cad-plated bolt or washer for an un-plated one calls for, respectively, a 15 or 25 percent reduction in applied torque, because the plating acts as a lubricant. Fail to heed this advice and the fastener will be seriously over tightened.
Aviation maintenance since 1967.
