selnoil's avatar
selnoil
Good Year Endurance Tires
I need to replace my bad 235/80r16 "Blowmax" tires. Had one blow out doing $4500 damage to the camper. My rims are not rated for the 110 PSI of the Sailun so been looking and it seems many of you like the new Endurance ST tires.
Can we get a few reviews and mileages plus trailer weights you've tested them with. My 330RBK has a GVWR of 12,265 lbs.
Mike
  • fj12ryder wrote:
    Wild Card wrote:
    You dont have to run Sailuns at 110psi either
    You may not have to run them at 110 psi, I run mine at 95 psi, but I don't know that I'd recommend running them at 80 psi either. That just seems really low to me.
    I went from the GY "E" to GY "G" on my Avion that had the E tires maxed out. With GY's advice I ran the G's 85psi for many thousands of miles with perfect tread wear and were cool running.
    Firm believer in using the load/inflation charts and adding 5psi per GY Tech support.
  • Learjet wrote:
    I don't think they have been out long enough for good reviews.
    Have you thought about Michelin XPS rib? I have the same rims and weight as you and will be going with them soon.
    The Bridgestone Duravis R250's cost less and are as good or better than the ribs. Used both on last trailer.
