selnoil's avatar
selnoil
Good Year Endurance Tires
I need to replace my bad 235/80r16 "Blowmax" tires. Had one blow out doing $4500 damage to the camper. My rims are not rated for the 110 PSI of the Sailun so been looking and it seems many of you like the new Endurance ST tires.
Can we get a few reviews and mileages plus trailer weights you've tested them with. My 330RBK has a GVWR of 12,265 lbs.
Mike
  • rhagfo's avatar
    rhagfo
    Explorer III
    If I were you, I would go to an LT truck tire! The 235/80-16 should have a rating of 3,042# ea. For a total of 12,168#. Keep in mind from your 12,265# GVWR subtract you pin which should be about 2,400# leaving less than 10,000# on the axles.
    There are several commercial LT also, personally with a 12,360# GVWR I have Yokohama YK-HTX on my 5er.
  • The Endurance was just introduced around the first of Feb this year. Only 4 months ago, so there is not going to be much in the way of mileage reviews. Or really much time for performance reviews of any kind.
  • I don't think they have been out long enough for good reviews.
    Have you thought about Michelin XPS rib? I have the same rims and weight as you and will be going with them soon.
