Sort By
- MarkTwainExplorer
marpel wrote:
I am of the same mind as Mark Twain, to me tires are the most important items on a trailer (and tow vehicle for that matter).
The last set of tires (also Goodyear Endurance) I bought 4 years ago, arrived at the dealer with two year old production date. I was not happy, but the dealer said "take em or leave em". Unfortunately, I was about to leave on a trip so had no choice.
So, they are now 6 years old (even though only 4 years of use) and I am shopping for replacements (at $1000 CDN, for 4 trailer tires...jeeez). Under different circumstance (short trips, easy speeds), I would likely let them go another year or two, but our trips are always long distance (BC, Canada - Denver, Co) on Interstate Highways at 64-65 mph and I won't take a chance getting a high-speed blowout in the middle of nowhere.
As others have suggested, it probably should depend on your anticipated use (short vs long trips etc) and how well you have cared for them, among other things.
Marpel - It is good to know that other people share my opinions of RV tires. I had the same problem with tires not being more than 1 yr. old. I called my tire dealer 6 months before I planned on buying new tires and told them I would not accept any tire more than 1 yr. old. Les Schwab in Calif. They had to search for them but finally got them.:) - AllworthExplorer IIWe have gone through a lot of tires in the last 20 years and I switch the rubber on the big (13,000 pounds GVW) trailer between year 5 and year 6. I'm not risking a failure in the middle of nowhere and I'm too old to be changing heavy tires by myself. We did get GoodSam to come all the way to Tombstone AZ from Tucson one time, but three hours in the sun in July waiting for the tire truck made a believer.
I do downrate my take-offs. Either for my son's landscape service trailers or on the local internet with the clear warning that they are cheap but should be considered for local use only!
Good tires are like a good rain suit. Basic to RVing.
A - marpelExplorerI am of the same mind as Mark Twain, to me tires are the most important items on a trailer (and tow vehicle for that matter).
As others have suggested, it probably should depend on your anticipated use (short vs long trips etc) and how well you have cared for them, among other things. - ScottGNomad
Cummins12V98 wrote:
ScottG wrote:
Mine are 5 y/o this year as well and I have no intention of replacing them just because of age. I will have to replace them next year because they'll be worn out - at <15K. They'll be replaced with something else that starts out with more tread.
Makes no sense! 15k??? I have a set on my Boat Trailer and they have at least 20-25k and dated 2017. I will run them this Summer and see how the tread looks.
You must have brakes set too tight or some other issue.
Something to consider you have 5 years with no issues on trailer tires that says a lot.
Brakes are self adjusting but I check them each spring anyway - they work perfectly. I do all my own mechanicals and know what I'm doing. I use my exhaust brake so they get a break that way. Tread wear is even but the rears wear slightly faster. Probably a factor of tight turns but nothing different than any of the other trailers I've owned.
I'd like to get alignment checked but there just isn't anyone in the area.
Biggest problem I see is that they don't start with as much rubber as other brands. Most have 50% to 100% more tread. - Cummins12V98Explorer IIII am fairly sure the warranty is 6 years pro rated for non road hazard issues.
Something to consider you have 5 years with no issues on trailer tires that says a lot. - JIMNLINExplorer III
Njmurvin wrote:
My Goodyear Endurance tires just turned 5 years old. Some sources say tires age out at 5 and others say 6. The price of these tires has gone up 50% since I bought them. I’d love to squeeze another year out of them but not if it’s too risky. Thoughts?
Depends on several factors. Some are....
Are the tires a commercial grade steel carcass tire. Their good for 8+ years and 50k-60k miles of service. Not so much poly carcass tires.
Have they been protected from the sun while not in use. Lots of rv trailers may make 3-4 trips a year with low miles of service.
Tires need to be used so how many miles do those tire have in those 5 years.
Have they had the proper care in those 5 years....no derated per minimum load pressure charts..... Bounced over curbs/rocks/etc. - cummins2014Explorer
Thats pretty poor performance for any tire 15K . If you got the rims for it move up to the best in an RV tire, the Sailun S637 . - MarkTwainExplorerFor me, tires are one of the most critical factors when evaluating RV risks when traveling. IMHO.
So, I always bought new tires at 5 to 6 years IF I was going to take any cross country trips, especially if traving in areas with hot tempetures. Short trips I might take a chance on 6 year old tires. At 7 years, I throw them away for new tires.
Tires are expensive for sure but the cost of damage to your RV or worst scenerio an accident when you have a tire come apart :( - Home_SkilletExplorer IITires are cheaper than repairing your RV due to a blow out.
About Fifth Wheel Group
19,013 PostsLatest Activity: May 18, 2025
