Cummins12V98
Sep 04, 2014Explorer III
Chalkie wrote:
I just had G614s installed on my coach. Discount Tire went the extra mile in researching that the tires would be compatible with the wheels and that the added tire pressure was also in line with the rating of the wheels. They look good on the coach and even though a bit larger than the originals have plenty of clearance. Heading out on Monday for a 3 week 2500 mile trip, we'll see how they roll.
Don't just blindly run the tires at 110#. Weigh your RV compare the weights to set your tire pressure with the weight/inflation guide for your tire. Add 5psi tho the heaviest tire, this is per GY Tech Support when going up in tire rating.
With 110# you will have a rougher ride, wear the centers of the tires and have less stopping power.
I did this mod with our 02 Avion Platinum. Ran the G's at 85psi at 5 years of use the tires were the exact tread depth. The reason for 85psi is because the E tires were maxed out so it makes sense that the G's would need 85psi.
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
