JEBar wrote:
MrVan wrote:
That is absolutely amazing. Three failures and still using the same tire size, model and brand? Why not buy a tire that doesn't fail?
OK, give me the name of a brand that is guaranteed to never fail .... wait a moment I'll make it a bit easier, give me the name of a brand that is guaranteed not to fail for 5 years of use with little, if any, regard for miles of use and I'll give it serious consideration .... my bet is you can't do so, nor can anyone else because that tire doesn't exist .... until it does, I'll stick with the only one that will pay for the damage .... as others have noted, the failures we experienced were years ago, as best I can remember the last one was back in '06 or '07
Jim
There are no tires offered guaranteed not to fail, but there are tires available with much lower failure rates than what you have experienced. Staying with the same that has failed repeatedly is amazing and does not make good common sense!
