NC_Hauler
May 31, 2016Explorer
:R
:? Look at a HDT?!? OP doesn't even want a dually!! A 1 ton dually would EASILY TOW A 16K GVW 5th wheel! No need whatsoever for a semi cab.. My truck has a GVWR of 14K, and with Aisin tranny and 4.10, has a GCWR OF 39,100#! You need to re-look at capabilities of the newer 1- ton Duallys.
If OP GETS RIGHT CONFIGURED 1 ton SRW, he can tow a 16K 5er with it
To the OP.. Short bed cuts down on GCWR, and may cause you to possibly need a slider... If you don't want a dually as your daily driver, make sure you get the right truck for the job, or don't go heavier. A 1 ton dually has been my daily drive for 11 years now. I got a dually to be sure I had the right truck for my towing needs.
It IS for sure that it would be 10 times easier using a dually for a daily driver than a HDT.. Heck? I'd have a hard time parking it at work
waltbennett wrote:JnJnKatiebug wrote:
I am looking at a used Grand Design Solitude 369, GVWR 16,000, UVW 12,650, pin weight 2575. Also looking to buy a new tow vehicle that will be my everyday driver/fishing vehicle and I really want a 6.5 foot bed and single rear tires. I am thinking a 3500 GMC with a Duramax. Does anyone tow this trailer with a vehicle like this? We will be making one long trip each year and staying for two to three months then maybe two or three trips of less than 150 miles. I just don't want to deal with a dual wheel truck for an everyday driver.
I'd suggest you look at a HDT if you want something to really get around in. They've got the towing and pin ratings, but also much more venerability than a pickup based truck. I rode for a while in an International that I really liked and it would pull our Montana even better than our F350.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
