Old-Biscuit
Sep 06, 2013Explorer III
First thing is the confirm tank vent line is clear.
Next time you dump.......after it has drained go up on roof, remove vent line cap and run a garden hose down line. Then turn on garden hose and watch flow from tank.
A cut out will float around until it gets suck down against drain outlet.
The sudden rush when you first open drain valve and then slowing down sounds more like a vent problem
About Fifth Wheel Group
