Turn Key wrote:
You can but I wouldn't. Sludge will build up and dry in the bottom of the tank causing issues down the road. Better to let the grey water fill the tank and then drain it every few days. Will keep the sludge moist and allow it to drain away with the water. Your call, though.
Happy Camping!
X2
This is the right answer as to 'why'. :B
No water in either tank and stuff will stick to the bottom of the tank. Water is needed in both to keep things floating and flowing when you do dump keeping the bottom of your tanks free of food stuffs, grease, waste.
Not to mention that keeping the gray closed until dumping also cleans out your sewer hose after dumping the black tank.
