minz
Jun 27, 2013Explorer
Grey water tank shifted?
Trouble shooting a wiring issue with my refrigerator blowing fuses and my heater not working it appears that the grey water tank has shifted and pinched the wire bundle between the frame and the tank. The tank appears to be held in by a cross member that was secured to the frame. I have an empty tank so blocked it up, pulled the cross support and the tank does not seem to want to come down.
How is that tank held in?
Salem 2007 Forest River T25 Toy Hauler
More info: 15 amp fuse to refer blows but 5 amp at refer does not. Pulled hot wire on refer and furnace (same fuse). Still had 12 volts on the heater. Pulled all fuses still had 12 volts on the heater.
Following the wiring back found the bundle pinched on the frame. Looked at the opposite side of the tank and the bottom of the fabric was obviously torn.
