jimmyfred
Oct 15, 2016Explorer
howardwheeler wrote:
They do not remove the old roof as long as it is still secure. If it is not then removal would be an extra expense. I believe that is correct. But they treat the entire rubber with something that chemically stiffens the rubber. Then they do all sorts of work on every seam and penetration on the roof. They do this before they put the two coats of polymer on. If anything needs repair, they do that before anything else. They are stuck with the warranty if they miss something so they do a lengthy very thorough inspect prior to their quote and starting work. That's what they did with me. The whole first day of work was all prep work. My roof wasn't in terrible shape, but if it were ripped or bubbled they would have removed or repaired that first. Their whole system depends on the roof being properly prepared.
.............Did you pay them , after they finished or before , or maybe half when they started and half when finished ? , thanks , jf
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
