My wife was recently diagnosed with ALS and our previous fifth wheel was not going to work. Considered getting a unit from Dune Sport but decided against it. For at least $10k less got a Puma 351THSS. It is the only fifth wheel I found with the bathroom on the lower level, next to the garage. And there is sufficient space in the garage next to the bathroom to create a small roll-in shower. Our plan is to use an EZ Lite power wheel chair in the beginning since it folds and weighs 65 lbs. But when a heavy PWC is needed, I will either use a winch or extended ramp to load it, or add a Braun wheel chair lift. I can either widen the 2nd door or just cut a door thru the ramp.
I also have a plan to put a hospital bed in the garage north-to-south and use the existing electric bed lift as a transfer between the bed and wheel chair.
There are also a couple of Outback trailers with side ramps and forward garages that might also work for your needs.
If your looking for a TT instead, the Cherokee Wolf Pack 25PACK12 would be my choice. The garage is also 12 ft long and the split bath might work with minimal mods as a handicapped bath.
