83trekker
May 04, 2020Explorer
Hard side 5th wheel leak
My 99 Travelaire 5th wheel has split a part on the back left side of the trailer.
As you see with the pictureS BELOW , where should water drain? Should it even be going under the plastic molding that cover the screws right on the back edge of the trailer where the side and back meet?
What about at the top of the trailer should the water only drain off the metal horizontal drip rail straight to the ground or meant to run under that plastic cover for the screws?
