jus2shy wrote:
Something I found odd on this web page is the whole going 10psi above max pressure to go up to 75mph. However, many rims in the 14 and 15" sizes are not rated beyond 80psi. I'm guessing that the flex combined with the larger cords causes separation. While the finer/smaller cords probably provide more surface area for the adhesives to bond to. Personally, that sways me towards LT tires with the proper load ratings.
Goodyear is the only manufacturer that approves that procedure for their ST tires. None of the other ST manufactures approve it.
Even when approved by the tire manufacturer the trailer manufacturer would also have to approve the procedure and address its parameters in the trailer's owners manual. And, then insure the OE rims can handle the extra 10 psi.
FastEagle
