10drum
May 21, 2018Explorer
Harsh bounce on rough roads.
Greetings,
I purchased a used livin lite 7x20 toy hauler. 3500# dry weight, with 425# tongue weight. I pulled it back from Michigan to Illinois. My tow vehicle is a 2017 Nissan Titan with tow package. I test pulled the trailer in Michigan and it pulled well...in Michigan. Once I crossed over in to Indiana on I69, the roads beat me to death. I stopped and filled the holding tank, which helped a little. Ok, I thought, it won't be so bad once I load a couple of bikes and my stuff in the trailer.
Ive loaded it with two 400# bikes, no stuff, filled the holding tank, and installed an equalizer hitch. The truck tires have 40# (44# max psi) and the trailer tires have 50# (50# max psi). I have a good test road that is rough, perhaps not as rough as an Indiana interstate, but still rough enough. It is a little smoother, but still has a vertical shake when hitting the highway seams at 60mph, and now has some sway.
My wife and I pulled a 23' Avion back in the 80's with a 78 suburban, and I never experienced the roughness that this set up has.
I am open to suggestions.
Thanks for all replies, Phil
