schlep1967
Aug 28, 2020Nomad
My first question would be are you capable of lifting it in and out of the truck bed? If you can do that and you are concerned about hauling it behind the trailer, put it in the bed of the truck and remove the worry.
If the generator is too heavy for you to lift that high, put it on the rack and check it often. What is the receiver rated for on the back of the trailer? 100 lbs is really not that much for most of them. Strap it down tight, lock it and cover it so it is out of sight.
About Fifth Wheel Group
