azrving
Aug 28, 2020Explorer
padredw wrote:
This is strictly for the OP and not for argumentation. I have almost exactly the setup he is considering and have made several trips to Colorado without any problems. I do use the generator to cool off the trailer for about half an hour before lunch stops and night time stops, and I do use the generator for brief periods of time in off-grid campsites.
To OP: note the 30 amp connection from our home base and the comparable 30 amp cables on the hitch carrier. Note how short and direct a distance I can connect from the generator into the 30 amp connection to the trailer.
I bought this used generator, the hitch carrier, and the wiring from a friend with the same trailer model as ours when he stopped RV travel.![]()
Moderator edit to re-size picture to forum recommended limit of 640px maximum, width.
Hard to beat a Honda. I’ve got about 1200 hours on mine with it only needing a battery and regular oil changes and valve check
About Fifth Wheel Group
