SanMarMor's avatar
SanMarMor
Have you measured your tanks?
Have you ever measured your waste tanks. Our trailer only has 42G of fresh water, yet has two 42G grey and a 42G black tank. When we run off tanks only, the 42G of fresh can fill all the other tanks to 2/3 full. That doesn't make sense. I know gauges aren't accurate. But my curiosity got the best of me. So I measured all three holding tanks. I filled them all with a graduated bucket, till they backed up to where I was filling them. They are all about 36 gallons, and actually, that includes the plumbing leading to them. So I have been shorted what I've paid for by about 20G or more. To my thinking, that is false advertising.
I'm going to write them, but I know they won't do anything. Have any others noticed this on your trailer?
Mark
  • Never measured it, but definitely noticed that the black tank on the trailer I used to own filled up (checked visually not by gauge) MUCH faster than it should have. Capacity seemed to be about 1/3 less than stated... about 18 vs 24 stated.
    This become pretty obvious when dry camping and paying attention to how much water you've used.
  • therink wrote:
    If you are going by the gauges as 2/3 full, take into consideration that those level gauges are far from accurate. The only way to truly tell the tank capacity is to fill with measured gallons via buckets down a drain/toilet.
    Did you read the OP? :S
  • What would you want the manufacturer to do?
    I really doubt they will change the tanks.
    Could it be a safety thing, having the actual capacity less than the advertised capacity?
  • If you are going by the gauges as 2/3 full, take into consideration that those level gauges are far from accurate. The only way to truly tell the tank capacity is to fill with measured gallons via buckets down a drain/toilet.
    Sorry didn't read it through.
