MFL
Mar 30, 2016Nomad II
You mentioned first FW, but do you have experience towing other trailers? With most trailers, you can only turn so short before hitting. A FW is the same, you just need to be aware when turning really short. If you have use for a goose neck ball then the Companion is a good choice.
I would not be concerned about bed rails, if you needed to go that route. If you cut out a rubber bed mat to fit around the rails, it's like they aren't even there with the hitch removed.
Jerry
Jerry
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
